mR_CaESaR
After seeing both @nnap's and @skate323k137's Tenkgou threads, I knew I also had to do it myself
I reached out to @alberto1225 to hook me up with the Panel and @xb74 of CQB Arcade to see if he was able to source out the required buttons for the panel. I figured it was better to support the local business.
The following was ordered
Fast forward to a few days ago, all the buttons arrived with a nice little extra items, props to CQB as my kids enjoyed the extras
Each button can be disassembled so artwork can be placed under the top cover - thanks for including them in @alberto1225, I screwed up A on the P1 side and my OCD is being triggered, but I have to live with it as I only had one set haha
Once all installed, it should look like below. This will be the closest I can get to the original without having the dedicated cab. The main difference is the size of the buttons, the original directional buttons are 45mm vs the 30mm on this panel and the size of the A and B buttons 60mm on the original vs 45mm for this panel
Next was to start the wiring harness. Since this will be going to the Blast City and that cab doesn't have a dedicated JVS I/O, I thought something like this would be a decent way to rig it up whilst having the ability to use the existing connector for P1 and P2 on the blast city.
I got shared the wiring schematic of the game by @Lemony Vengeance and Tak and based on the information from the schematic, I ended up with this schematic (colours are my chosen colours based on wires I have)
For the directional inputs (same as a standard sega joystick)
For the LEDs
Some stats for the panel harness -
What a mess of spaghetti!!
This is where the multi meter does wonders! Because of my colour coding, I had accidentally wired up 12v into an input, that would've been interesting to say the least
After a few hours of looking at the schematics, crimping, cutting, testing for continuity, here's the control panel in its final form - cable ties ftw!!!!
Next up, I'll need to make another harness from the JVS I/O to these connectors.
- 2x OBSAX-C30UM-W-1FLED-W-12V (start buttons)
- 8x OBSAX-C30UK-W-1FLED-W-12V (directional buttons)
- 4x OBSAX-C45UM-W-1FLED-W-12V (A and B buttons)
For the LEDs
- 14x JST NH 4 Way
- 112x Crimp connectors
- 56x wires totaling around 4m give or take
- 4x different connectors (2x TE Amp Up 12 way, 1x TE Amp Up 8 way, 1x JST YL 12 Way)
