Orakelschaf
I got a Naomi 2 PCB which ran fine. Naomi Logo showed up, but the setup menu showed garbled Text. I figured out it that IC107 and 109 are bad.
To clarify:
- I replaced IC 107 and IC 109 with new RAM
- I accidently desoldered IC7, but soldered it back in (was about to desolder one of the other ICs, but moved a bit too left )
- No solder bridges, all pins are soldered (tested)
- Afterwards the Naomi2 only showed a blank screen. The monitor gets a video signal, but no picture is shown. I guess the Naomi2 hangs before the boot logo
- I desoldered IC107 and 109 again and put in the old RAM, without success
- What can cause the sudden blank screen? (what could i have damaged and what is the general for a blank screen (not a black screen!))
To clarify:
- The Naomi2 ran "fine" before. Ran fine with removed supercap, Bios and replaced fans. The filter I/O works fine
- PSU provides enough power, pcb test points meassure correctly
- Video output is not black, it is blank. (Displaying a blackish picture )
- Boota nimation never shows up. Ran the Noami2 for 30+ minutes
