kinooshi823
New York
Installed the multi but for some reason. Lindbergh chooses the SSD as the primary master. I remove the SSD then the CF is the master. I believe I have the jumper settings right unless it could be a possible interference from the IDE to SATA adapter. I changed the jumper settings on that, but the Lindbergh doesn't boot. What am I doing wrong here?
Why do you use an ide to sata adapter? The lindbergh has sata ports? ( and it works fine? )
Show us what tou believe is right with a picture and we’ll tell you what we believe ;)
IIRC the SSD has to be set to slave, and if your adapter isn't working try another.
Update to this. I got the startech IDE to SATA put it on slave, boots. Now I have another issue. White screen shows now loaded, yellow stipe gets to full and it just stays there. What could it be?
Not op but about to take a dive and buy a Lindbergh. I've read some games have issues due to the Linux kernel version/data driver issues. 🤷‍♂️
Hard drive may be Failing.
I had same issue,
New multi worked.
I tried to write my own cf etc..
But I couldn’t get it to load.
Bought a new drive and it just worked.
Annoying as it was working ok on ssd,
After I copied it to the ssd .
Now I’m back on optical again!
Can’t get sound card to work now though!
Hmm, I don't k
Re: https://www.arcade-projects.com/threads/is-yatonarcade-legit.27483/page-2#post-400425
Are you still using the SATA to IDE adapter? You shouldn't need to with the multi from archive.org.
Yeah since I don't have any spare sata cables and such. I do have some on the way from amazon with the molex to sata connectorss. The converter I used was reserved to use on my OG Xbox that I plan to put an aladdin in soon.
Yeh sata cables can be fussy too
Best to have a few different styles/types
