arcadeaction
FL, USA
Hi - perhaps this has already been discussed, but is the Japanese version of Radiant Silvergun available to play on the ST-V multi? I'd like to use the three button controls. Is a multi bios necessary? I believed I had purchased all the options at time of order, but wondered if I had to do anything special for this. Thanks
You have to enable Japanese mode with multi bios of use a Japanese bios.
Do I need to buy and install a multi bios chip for this? Or is everything I need already included in my multi kit to run multi bios? I didn't quite understand.
Also, how do I enable the multi bios?
Thanks
Either you install a multibios chip or Japanese Bios chip on the motherboard. If you have a multibios chip installed then you will select japanese region on boot. The multibios chip does not come with the multi. You need to buy one from somewhere separately.
