chacal231077
France
Hi! :)
I purchased IMAGENICS RGB FRAME SYNCHRONIZER RS-1500, but there is no option to rotate the screen.?(
I read that in the instructions that it is only available from a firmware version. I'm disgusted that mine has too old firmware F:1.2 P:2.5 ;(, if I had known there was this kind of problem X/
The following functions have been added to this product in software version F:4.0 P:1.5 or later.
1. Ability to rotate output image 90 degrees left or right.
2. Added 2048 x 1152 and 1024 x 768 resolutions to the input side EDID emulation function.
3. Super simple cross hatch function to enter video. (Auxiliary function for multi-screen setting)
Due to the addition above, please read the contents of this instruction manual as follows.
1.The OUT.MULTI.SET menu displayed in the main menu has been replaced by OUT.ROTATE.MULTI.SET.
Added OUT.ROTATE.MODE item to OUT.ROTATE.MULTI.SET menu
2. Add 2048 x 1152RB and 1024 x 768 to the IN.EDID.SET element
3.Add the IN.CROSS.MARKER item to the OUT.ROTATE.MULTI.SET menu"
I sent a message to imagenics in Tokyo Japan to find out if we can do it with a method. I'm waiting for a response from them :saint:
if anyone has an idea, or dumped a firmware from another more resent ;(
if anyone has an idea, or dumped a firmware from another more resent I really don't see in which component the firmware is located. X/
Thank You for Help :thumbup:
