streetfighterken
Sioux Falls, SD
Can someone do me a favor and test FOTNS on their AW2Naomi? If I coin up at the title screen, I can play the game. If I don't, it will hang at a black screen (normally it would go into demonstration). Also, when my game is over and I enter my initials, it will hang at black screen.
  • Naomi 1
  • Net Dimm 3.17 512MB
  • via PiForce-Single SD
  • Sega 837-13551 JVS
  • Tried these BIOS: H-21577 USA, G-21576 Japan
Which JVS are you using? Capcom? Pciture or link to picture please.
I've played quite a bit of FOTNS on my NAOMI and had no issues. 512mb NetDIMM, Namco JVS IO (Cyber Lead) running export BIOS (multi BIOS with DIP switches set to export)
NetDIMM is 4.01 - I actually thought you needed to be at 4.01 for Atomiswave?
Can you try USA? I thought 4.01 was for CF and not necessary for net boot.
It probably is, it's just what was on my NetDIMM when I bought it, I actually thought 4.01 was for Atomiswave and 4.02 was CF but it's been pointed out I'm wrong there :P
The good thing is it means I can boot from either source I guess.
I'll try the USA BIOS and see what happens
I think I figured it out. If region and language is set to Japanese (default), it works as it should. Wonder if all AW games let you break the game by switching regions ?( It seems to be independent of BIOS (mine is H-USA).
what if you run the region changer on it?
