nnap
Switzerland
I have CPS2 A-Board that displays wrong colours. The colours are all over the place when I look at the test screen, so I suppose it has something to do with the palette ram. Does anybody know where that is located?
What are you running it on? A cab? Supergun? Do other boards work correctly? Have you tried another A board to determine where the fault is?
I am running it on a supergun but have also tried in a cab. The B-Boards have been tested with a working A-Board, so the fault must be in the A-Board. I have also cleaned the connectors and checked the customs for lifted pins. So far I have not found any faults.
