supabok
Norcal
$300 $250 shipped in the US.
Bought this supergun during the pandemic and it's been sitting on a shelf ever since (I think i've turned it on maybe 4 times just to test it). Never got around to actually using it since I bought another cab at some point.
Tested working via RGB cables & 8pin SCART cable to OSSC to HDMI. Note: this version is the basic setup so there is no HDMI output and you'll need something like an OSSC to output to HDMI. It does work fine if you run it out via RGB to a CRT monitor :). Haven't tested sRGB.
Comes with AC cable, jamma extender cable and RGB cables. Plastic wrap is still on the face of the unit (which shows how often I've used this).
Stick is Seimitsu & buttons are Sanwa (that's how it was sold).
So if I use something like an rgb2comp to connect this to a consumer CRT I should be good right?
I would imagine so but I don't have an rgb2comp so I can't test it out for you :(
I did try this via rgb on a CRT and it worked just fine if that helps
Edit: correction, audio out on this unit is via a headphone jack that splits out to l/r audio inputs
