Mitsurugi-w
Arcade Admini-Moderator
New Bern, NC USA
Deluxe Power Harness for Chihiro and Triforce SSD/CF kit:-----$15
This power adapter allows you to power your SSD kit using the headers available on the motherboards of these respective setups. The adapter has the necessary connector for both Chihiro and Triforce on one cable!
Standard Power Harness for Triforce or Chihiro (pick one) CF kit only:-----$8
This power adapter is a simple harness to power your standard IDE CF adapter in your Triforce or Chihiro pcb when using Darksoft's custom firmware. Choose which system. This harness will power your CF kit using the headers inside of the system. No external power needed!
UPDATE!!!:
I changed the name of the harness for Triforce and Chihiro SSD kits to the Deluxe Harness for Triforce or Chihiro SSD/CF kit. I also added basic power harnesses for both Chihiro and Triforce for use with CF kit only. You choose the system you need it for. They are priced at just $8.
Also, all power harnesses now use the proper 6-pin JST connectors that Sega uses. :)
So 7 cables total? Send me a PM to order.
