Do any of you tried to repair naomi carts?
I don't know why but looks like ZERO GUNNER 2 has a 80% failing rate. I know a lot of friends, mine including, that have this game with the infamous/random BAD IC (it could be all BAD or most cases IC7/
I've never read about someone that was actually able to fix this problem.
Some of them talk about a bad tsop rom, others clue about some buffers on the pcb (LVCH16245A and LCX16373).
My board was in the worst case, giving me all of the roms in BAD while doing tests. That, to my opinion, was really unlike to be the real problem, so i started to doing some work on it.
First i compared the 27c322 bios with the dump, winmerge told me was the same.
Then i went for Aliexpress and bought all new buffers for it, tssop48. I soldered them with my hakko and check with a digital scope for good connections and bridges. I've read many complaint about these, since i was not able to test them with my probe i decided to change all of them in a row.
Guess what? Nothing changed.
Then i went for change all of the smd caps just to be sure those were fine and again nothing happened.
I'm actually stuck here.
Do any of you had some experience with these?
