This is an updated first post reflecting the current status of the project. The original post is preserved behind the spoiler tag down below.
The Vewlix Console I/O V3 is a drop in I/O for the Vewlix control panel that allows you to easily connect 2 Brook fighting boards, or other compatible controller PCBs to your Vewlix controls without any custom wiring or modifications needed. This is a convenient and feature rich option for those who wish run consoles or PCs in their Vewlix cabinets.
Features:
You can map the coin mechanism to trigger a button press by pressing and holding one of the following button combos while powering on your Console I/O.
Price and Ordering Info:
Console I/O V2 and V2.1
The Vewlix Console I/O is a drop in I/O for the Vewlix control panel that allows you to easily connect 2 Brook fighting boards, or other compatible controller PCBs to your Vewlix controls without any custom wiring or modifications needed. This is a convenient and feature rich option for those who wish run consoles or PCs in their Vewlix cabinets.
Features:
Console I/O V1
Features:
- Adapts the Vewlix "G" control panel wiring harness to 2x 20 pin headers for connecting Brook or other compatible arcade stick PCBs.
- Home/Select/Touchpad/L3/R3 button emulation via button combinations.
- Custom button mapping of the coin switch of the coin mechanism.
- Coin switch iterates your cabinet's built in coin counter.
- 6 pin JST XH auxiliary wiring harness connector for connecting home and select buttons to an external button panel.
- 2X 4 pin JST PH connectors for wiring the touchpad emulation to your player 1 and 2 Brook fighting boards.
- Power passthrough for 12V from the cabinet power supply, and 5v from the controller PCB power.
- Diodes on the power lines to isolate the 2 controller PCBs from one another.
- Drop in replacement for a Vewlix I/O.
- Select = B1 + B2 + Start
- Home = B2 + B3 + Start
- Touchpad Button = B1 + B2 + B3 + Start
- L3 = B4 +B5 + Start
- R3 = B5 + B6 + Start
- Start = Start
- Select = B1 + B2
- Home = B2 + B3
- L3 = B4 + B5
- R3 = B5 + B6
- Coin Counter control. The PCB is wired so that the coin counter will properly iterate any time the coin mechanism is triggered.
- Home/Select/Touchpad/L3/R3 emulation enable/disable. You can toggle the button emulation function on or off by pressing and holding B1+B2+B3+Start while powering on the Console I/O
- Base Price $39.99 USD, With L3/R3/TP Button Cables $44.99 USD
- Order here!
Features:
- Home/Select/Touchpad button emulation via button combinations.
- Touchpad Button = B1+B2+B3+Start
- Start = Start
- Select = B1+B2
- Home = B2+B3
- Home/Select/Touchpad emulation enable/disable. You can toggle the button emulation function on or off by pressing and holding B1+B2+B3+Start while powering on the Console I/O
- Price $39.99 USD
- Order here!
I'm at it again! This time I have a Vewlix IO replacement that adapts the 20 pin connector of the Brook fighting board line or my own MC Cthulhu EZ PCBs to your Vewlix control panel harness in much the same way as the Console JAMMAizer does. This is probably the easiest way to get a Vewlix running on a PC, PS3, PS4, XBOX 360, XBOX One.
Features:
I have tested all player 1 controls and functions, but I have not had a chance to test player 2. I currently only have a single player control panel in my Vewlix. I'll probably end up sending one of these out to another Vewlix owner for further testing. Once It's confirmed working we'll see what demand looks like to manufacture some of these. Let me know what you think!
Features:
- Integrated microcontroller for Select and Home button emulation via button combo.
- Auxiliary wiring harness connector for connecting home and select buttons to an external button panel.
