Vewlix/Chewlix
Davoserdach
Davos
Hello together
I have bought two new Chewlix and would now like to convert them accordingly for myself. I have also bought 2 Txx3 systems. The aim is to turn one into a 2 player cab, where you can connect a pc as well as the TTX. I would like to convert the second cab into a 1 player vertical shooter cab.
However, I am new to the cab trade and have a few questions that you may be able to answer
About the 2 Player Cab:
- What kind of connections do I need to play with the TTX and a PC? Is a Taito Fast IO sufficient or do I need a different system? How exactly can I configure the buttons afterwards?
About the 1 Player Cab:¨
- Are there any instructions on how to rotate and remount the screen?
- If the screen is rotated, where do I change the games in the ttx so that they run vertically?
These are the first questions at the moment, there will certainly be a few more
Until then, thanks for the help
Translated with DeepL.com (free version)
I don't believe you can rotate the monitor for a Chewlix without buying extra brackets but read this on how to rotate a monitor on a Vewlix. Here's a forum post where someone asks the same question. Unfortunately, I don't have the answer to your second question.
Hello everyone. I installed the fast IO in my chewvlix today. I pressed fas io enable on the ttx 3. Now only 5 buttons work in street fighter instead of 6. How can I configure the buttons?
Are you using fastio with jamma? If so you can try using the 60pin port to connect the button.
