ashasaur
Hey all, this is my last ditch effort to try and solve my Time Crisis 4 issues before I just take this cab to auction and hope for the best.
I've got a TC4 standard, original CRTs, guns, IO etc and I cannot get the left side to calibrate for love or money. The right side calibrates and works fine, issue is only present on the left. All the IR LEDs are functional. So far this is what I have done so far to try and fix this:
1 - Moved IR array from right to left, no change
2 - Moved gun from right to left, no change
3 - Moved IO in tower and near gun from right to left, no change
4 - Installed SEGA sensor in gun, no change (works fine in right side just FYI)
5 - Swapped all factory wiring from right to left, no change
6 - Painstakingly replaced wiring in tube and tower, no change
7 - LCD converted to see if smaller area would make a difference, no change
8- Removed/sanded gun lenses, no change
I genuinely cannot figure out what to do next. The upper right hand corner of the left side is where the issue lies - sometimes it can be calibrated there, most times not, and, even with a "successful" calibration, the gun sight is all over the place. Any help or insight would be greatly appreciated!
