Hello, I have a Sega Naomi 2 that I'm trying to get to Netboot with Pi-Force. My Naomi is 3.17 and I set the network to ethernet and the ip address is 192.168.1.2 and mask to 255.255.255.0. But I can't seem to get past Error 34.
Are you using a crossover cable? Just a regular patch cable won’t work. Are the jumpers set correctly for net booting on the netdimm? Also make sure you are able to ping your net dimm first with a pc.Hello, I have a Sega Naomi 2 that I'm trying to get to Netboot with Pi-Force. My Naomi is 3.17 and I set the network to ethernet and the ip address is 192.168.1.2 and mask to 255.255.255.0. But I can't seem to get past Error 34.
Looks like your pi came from the same seller I purchased mine from on aliexpress. It would not connect as well.Hello, I have a Sega Naomi 2 that I'm trying to get to Netboot with Pi-Force. My Naomi is 3.17 and I set the network to ethernet and the ip address is 192.168.1.2 and mask to 255.255.255.0. But I can't seem to get past Error 34.
Thanks! Seems to be the same issue. Appreciate it!Looks like your pi came from the same seller I purchased mine from on aliexpress. It would not connect as well.
https://www.arcade-projects.com/thr...-tri-force-chihiro-using-pi-force-tools.1086/
Page 33 on this thread has pics of the bad pi I purchased and pics of the functioning one I picked up afterwards. If you are looking to aliexpress you may look for the one I recommended.
