Sega Dreamcast Arcade Stick to Jamma
draculax1978
Germany
Hello i need Help.I will my Dreamcast Arcade Stick for Jamma conversion. Does anyone have the Dreamcast Arcade Stick Pinout or instructions?
Here is the pinout:
https://mc.pp.se/dc/controller.html
You aren't going to be able to straight wire it out to JAMMA - you would need a converter chip to take the MAPLE BUS information and drive a JAMMA out.
Not sure if anyone has already made this kind of adapter. Depending on the switches (if they are actually microswitches) you might be able to rewire everything - but I haven't seen what the insides look like.
Matt
Thanks.The stick came from a defective Consolized Killer Instinct 2. But it doesn't work on my Supergun because the assignment was specifically for the Ki2... Here's the inside... Something has already been done to it and it looks like the board is scratched
The cables are yellow, red, brown and orange. What color is the above control? I would need to know what colors is for top, bottom, right and left
Thanks.If anyone also needs help with a Jamma conversion, my picture will help. I just have one problem. Where do I get the +5 volts??? see Neo Geo Pinout, there is no cable left
Ok, I have everything connected correctly and as soon as I press a button on the joyboard, the supergun resets
Ok here,The Killer Instinct Sticks No Work😭
I did everything according to the Neo Geo Pinout. No button on the Dreamcast Stick works
The only thing I noticed is that the A (1 button) has 3 cables, and the others only have 2...
The cables go from the circuit board to the buttons. I see that something has been scratched away on the circuit board
