plasticfactory
EDIT: This is as done as it's gonna be. I would still like to do a few things, like potentially remake the heat sink (lower profile), and put some texture or pattern into the side pads. I'd also like to sleeve the cables, which I'll probably still do.
Behold:
I recently received a very dirty, partially working Primal Rage board. I have posted in a few forums asking for help with various things, and figured consolidating here would be best. First, it was absolutely filthy. I washed it in an ultrasonic with Branson EC cleaner for 4 minutes at 50C, then dried in an annealing oven at 175 for 2 hours.
Before and after pictures attached.
Unfortunately, I damaged a PLCC socket, but repaired it with some glue and a 3d printer as seen here:
https://www.arcade-projects.com/threads/damaged-plcc-socket.26251/#post-386768
Next up is the enclosure!
PS. shoutout to Birdland, those trays are killer!
Behold:
