Primal Rage 2 Cabinet Build
CoolFox
California
Finally made a Primal Rage 2 cabinet. Primal Rage 2 was going to use a Killer Instinct / Skins / War etc type cabinet with a Killer Instinct panel. A friend donated a Skins cabinet, so I have somewhere to start. This will probably be a little slow mainly due to the difficulty of securing high quality art.
Items that I have/done so far:
*Correct Killer Instinct control panel
*Repaired the main Primal Rage 2 board, recapped both boards, switched the HDD to a solid state Disk on Module
*Correct color buttons/joysticks
*Recapped power supply
*Working monitor with a recapped chassis
*Took off all the Skins/War art
*Replaced speakers
Things to do:
*Secure Primal Rage 2 art (oh boy) *DONE NOW*
*Wire up everything *DONE NOW*
*Buy a plastic cover for the panel *DONE NOW*
This has been a project 5 years in the making. Mostly cause of the side art. I took low res picture of the side art, had it enhanced and touched out by a friend/out sourced it. (No Thanks to Atari Scott who ignored my pleas to take pictures of his cab, hell he even has original art scans).
tn_work.jpgtn_4.jpgtn_2.jpgtn_1.jpgPhoto Feb 20 2023, 4 21 23 PM.jpgPhoto Feb 20 2023, 4 21 13 PM.jpgPhoto Feb 20 2023, 4 40 03 PM.jpg
This looks great, I'm not sure why this didn't get more traction here. Is that an original Primal Rage 2 board? Where did you get it? I'm really unfamiliar with the PR2 hardware.
Yeah it's a real one. It's a development board version of it (same version as what's out there). Key difference between the regular Primal Rage 2 board and the dev board version is the Dev board has a sub board on back that allows you to debug it. Also you can change the Bios whenever you want cause it's a simple 27c040 instead of that SOP44 nonsense on the main board. Primal Rage 2 hardware is on the ZN1 hardware. I got it years ago when someone listed it on ebay as "Playstation Arcade" (Cause that's what it says on the back). I guess he didn't know what it was at the time.
Absolutely crazy. I gotta know -- what'd you pay for it? Do you know how many dev boards exist?
Uh, I think I paid around $200? So far I haven't seen another one. I've seen a few of the regular primal rage 2 boards, just not another dev kit.
