FOUND Naomi Marvel Vs Capcom 2 unlocked eprom
Item has been found
Bjt
the Netherlands
Hi all
I am looking for the eprom that I can install on my naomi Mvc2 cartridge.
Found ^^ Thanks Nem
Could we use buyicnow for this? Not sure which chip to use or which ROM, even... I'd like to pester you for one of these, but I don't wanna make you deal with international shipping just for that. ;)
I should probably also do the freeplay hack to my 2X board...
You can if you want, it's a 27c322, or I can send you one Tomorrow morning :)
https://www.ebay.com/itm/115580272893
Edit: If you're not in the US. No worries. M27C322 at BuyICnow should be fine. Wasn't sure by your location.
Is this the solution in Error 01 in my Marvel vs Capcom 2 romboard?
I was asked this question via eBay recently too; I would not expect this IC to fix that error. Check your BIOS and start running self tests on the NAOMI and ROM board if you can.
