Naomi 2 ERROR 1
santa978
moorpark, California
How do I fix error 1 on a naomi 2 board
Cart not seated properly is usually the issue, 02 would be a region/ bios issue
sweet thanks boss, just like you said not seated properly, I worried ill brake stuff if I apply too much force
but sometimes a little elbow grease is necessary :facepalm:
Error 01​
Display: THIS GAME IS NOT ACCEPTABLE BY MAIN BOARD.
Cause: The ROM BOARD (or DIMM BOARD) is not connected correctly to the MAIN BD. The NAOMI 2 ROM board is mounted on the NAOMI main board.
Countermeasures: First, turn power off, connect the ROM BD (or DIMM BOARD) correctly. If the status is not improved yet, the board may be malfunctioning. The NAOMI 2 ROM board software cannot run with the NAOMI main board. If you want to run the NAOMI 2 ROM board software, replace the NAOMI main board with the NAOMI 2 main board.
