I just got two Namco Noirs. These cabinets are kind of hard to find information about. But luckily, they're pretty easy to take apart.
You'll need a security Torx bit (it's t20something, just get a set), 7mm, 8mm, 10mm sockets, #2 JIS screwdriver (do not use a regular Philips), and a flathead screwdriver. I used an impact driver on all the 10mm and security screws so it went way faster than if you do this all by hand. I would not recommend power tools on the JIS screws.
Removing the control panel
Open up the control panel by unlocking the top door and sliding the control panel lever thing to the right. Disconnect the connections for controls and the led lights.
Undo the two screws on each side, on the inside, that hold on the plastic trim.
Remove the two security screws on the outside. The trim will come off with some force, there's clips on top. Do this on both sides.
Undo the two 10mm bolts on both sides.
Undo the two 10mm bolts underneath the panel.
The control panel can now slide out and away from the cabinet.
Disassembling the control panel housing
Noirs are notorious for rusting at the wrist area. If you want to properly clean it up, you'll need to remove the top housing from the panel assembly. I ended up sanding mine down with an angle grinder and getting them powder coated.
Remove the actual control panel. There's 6 7mm nuts holding it.
Remove the 6 screws that hold the front plastic trim.
Remove the C clips from the side hinges but don't disconnect them yet.
Remove the 5 screws that hold the top housing to the hinge.
Now just slide the side hinges off the posts. There's a washer on either side.
