Hello!
I'm happy to announce the new Multi JVS 1.0!!! It's a brand new JVS PCB that supports the usual pinout that you can find in most SEGA cabinets and in addition to that 2x NEOGEO Pads.
It's fully compliant with JVS and it even has a function to Identify itself with whatever ID we would like.
This time is a collaboration with @winteriscoming. The software is his and the PCB is mine.
@Mitsurugi-w already tested it and will shoot a video about it soon.
@Derick2k will be getting also one as a thanks for his unconditional and continuous support to us and to this community.
Update Nov 17th 2020
I tried with many JVS games from Naomi, Lindbergh, Ringedge 1 and 2 and it works great.
It supports both analog and digital inputs and has the standard 26 pin input for analog controls. It supports up to 6 channels of Analog inputs, which can be configured in a very simple way.
First batch of 30 units is ready. PM if you want one. Price is 120 EUR + 8 EUR shipping. The capabilities of thie JVS are very wide as it can be used to play almost any game that uses a JVS protocol. On the top of that, as you can see it has 2xDB15 connectors so you can plug directly NEOGEO Joysticks! You can play all the Naomi, Lindbergh and newer Joystick games with your favourite Neogeo compatible joystick/pad.
Make sure that you read the instructions here: http://www.mediafire.com/file/hzgbqweo5rr95by/Instructions_MultiJVS_v1.pdf/file
