Exchange_Selects
I would like a pc that is already configured and ready to be hooked up through a JPAC to my Astro City. Just want play some MVC 2/Killer Instinct/ and some 3rd strike on fightcade. Thank you
With GroovyMAME or similar and the correct configuration you can get low resolution. Some relevant reading:I was under the impression that you couldn't connect a PC to an Astro City. I thought it needed a high definition CRT to be able to do so.
It’s not hard man. I actually have a groovy setup at home in my soon to be gameroom. I’ve actually taken it and put in on my tri sync monitor and it works fine but, it actually lives with a 27” Trinitron hooked up to it since the wife likes to play Tetris and Super Puzzle Fighter.really hoping someone has or can make a rig that does 15khz 240p, I am long overdue for this thing to upgrade from a pandora box.
I do not have a preference on front end, as long as I can play games like 3rd strike, Killer Instinct, MVC 2, through fightcade as well. You make that happen I got money for you. I would really appreciate it. Will finally have something to throw in my Astro City.It’s not hard man. I actually have a groovy setup at home in my soon to be gameroom. I’ve actually taken it and put in on my tri sync monitor and it works fine but, it actually lives with a 27” Trinitron hooked up to it since the wife likes to play Tetris and Super Puzzle Fighter.
I may have a spare Pc laying and may be able to throw something together for you
MVC is a 31k game natively. I have another Pc setup in a cab just for that res. All the others are no problem. I work on the road 6 weeks at a time and home for 2 then back out. I’ll be home Monday but will probably spend the first couple of days with the family. I’ll on you with whatever I can come up with once I check and see what I still have.I do not have a preference on front end, as long as I can play games like 3rd strike, Killer Instinct, MVC 2, through fightcade as well. You make that happen I got money for you. I would really appreciate it. Will finally have something to throw in my Astro City.
yesAre you trying to play Fightcade online with this setup?
I’ve e never messed with the fightcade setup. Been meaning to but just haven’t gotten around to it. As far as groovy, I’ve never had an issues with it scaling to the right res.The Fightcade 2 UI barely scales in any useful way to 640x480, let alone 320x240. I highly recommend using your cab as a secondary monitor with a normal primary monitor to control the UI.
All you need is an AMD card with a VGA port, CRT Emudriver, and maybe CRT Tools.
Doesn’t look like the ui is made to run that low of a resolution.This is Fightcade at approximately 640x480. Even if you do a horizontal super resolution you can't really read anything in 15khz. I'll take some real off monitor pictures later.
