Killer Instinct 2 Pcb Black Screen
draculax1978
Germany
My Killer Instinct 2 circuit board is defective. Need help. I got a Ki 2 board that should actually work. There was a converted hard drive with power connection, sound, etc. Screen was blue,then Red with Danger Danger Sound. I ordered a new SSD kit with Rom. Now there is only a black screen. Can anyone help me? Fan turns... Pcb comes Black Screen.With and Without Ssd
Screen black you can only hear a loud humming/whirring sound and no Red Led
Did the game ever run with your setup? Do you have another SuperGun/MAK than the ArcadeForge one you could try? I have a "Mace the Dark Age" pcb (like KI a Midway/Atari board) which doesn't run with the Arcade forge SuperGun/MAK but works on a different setup (missing -5v maybe)
I resoldered the CPU. Now there's a picture and sound and it shows Fulgore in the opening credits then it always goes into the test menu. I've already tried 2 superguns, no change. What's going on?
Check your DIP switches? Test mode might be on or the line could be triggered incorrectly
Also check the pin on the JAMMA edge for the test menu - it could again be getting triggered incorrectly
