tiff_lee
Picked up a "Outrun 2010" arcade cabinet which is pretty much a like for like a sega cab but with Chinese parts, @mR_CaESaR pointed out it actually looks like an Initial D knock off with the short marquee holder on top and card reader box on the side. Inside its running an original xbox connected to a conversion board going off to the pedals and steering pots.
Anyway it worked prior to moving brought it home and now no longer working, the chassis blew the 2A fuse so thought I would gather some more info and ill take a look over everything first.
The tube is Irico 64SX505Y22-DC02 and i've been unable to find much info on it, it is referenced here https://wiki.arcadeotaku.com/w/CRT_designation_systems, I was going to test the tube with my CR7000 just as a baseline measurement I do with all cabs but it's not in the manual, closest tube i've found was in a spreadsheet on Klov (64SX502Y22).
According to that wiki for Chinese tube designations "The second symbol consists of the letters SX followed by one to three numbers designating a specific CRT family whose members have common optical, electrical and mechanical characteristics" so yeah I got settings for 502 , mine is 505 how much of an issue that is going to be I don't know.
Also worth noting is the tube doesn't have the degauss coil underneath, there is the grounding strap that runs across the back of the tube but nothing else.
Chassis wise it has a Yatta 988, from what i've seen this looks to be a clone of the Wei Ya universal chassis, the silk screen seems to match and depending on what chassis you look at some have more or less parts fitted than others.
Anyone have any experience with this tube or chassis before? cheers
