Swoop
Texas
I just got a HAS Supergun and when using either my Brook NEO GEO converter or my DB152USB, neither is responding. The power light on the Brook converter nor the USB2DB15 is turning on and any device I plug into them isn't powered. The video and audio are working just fine and I coin in thru the supergun and the lights flicker on startup like the manual says they should. I've gone thru the manual and it doesn't look like I should need to do any special.
Any idea what could be causing this?
Thanks in advance.
Unfortunately I don't have any Neo Geo controllers. Thanks for the info @RGB, I'll look it it.
I went the DIY route so I just have the latest board from GitHub, not certain it is the same as the prebuilt ones, but from the discord it was mentioned to remove the 5V Protection bridge and do the bridge the disable protection. After doing that it worked.
