Hey there fellas . I'm new to the game of arcades . Purchased a maximum force that was playing blind . Opened it up and the monitor had no neck glow then I went for the plug on the chasis all wires where cut straight so I start to check around and found the jamma pix on line got it to turn on now but still a problem the degauss wire are still disconnected I'm not sure where to get the power for that . Not sure if it's direct 110 volt or is it off the switched power supply? Can any one help me out on this please . All I need to know it where to get my ac to power up the degauss coil as shown on the pin out image. All other pins are done. Thank you guys beforehand for any help
This is the full set up it's a zenith monitor 100 v with a ms9 29s chasis . With jamma wire set up a switch power supply. In line filter. the bord is a maximum force soon to be maximum force /area 51 upgrade
