mattsoft
SOLD!
I'm finishing up cleaning the basement and this is the final item and the most interesting.
Up for sale is a MiSTer FPGA "computer". What is this? It's a MiSTer FPGA inside of a Commodore 64 style case. OK, so exactly what is this thing?
This is a very, very, very nice turnkey C64-style MiSTer solution, and has seen only a little use as I have a couple of these built.
If you were to build this, the parts would be around $1000. Crazy, I know! Looking to get $620 + shipping
I am also happy to sell the MiSTer ITX stack (w/PicoPSU, 12V PSU, MT32-pi, 128MB DRAM, SD card, WIFI USB) WITHOUT the keyboard case and mouse for $400 + shipping -- you can plop it into your own ITX case!
Thanks!
Commodore C64X injection molded case with Cherry MX keyboard from myretrocomputer.com in the Commodore 64G color scheme -- white on white! This case supports ITX boards with 2 USB ports on the right side, a typical ITX panel on the back, a fan cut-out, and a left-side expansion bay. I have 3D printed (in black) a cover for the left bay, but you could put a hard drive in there or some other expansion. But you don't really need to with this build. The C64X comes in original box with manual.Ironclad ITX board from d3fmod that acts as the power board, USB hub, and analog IO for the MiSTer. The DE-10 is mounted on the board, and then the ITX board goes into the C64X. The back panel is 3D printed in black. The MiSTer has a 500GB SD card installed and the 128MB DRAM module. The board has an RTC with a new coin cell battery. I will also include a WiFi USB dongle to get this on your network.Also installed is the Ironclad hi-fi blaster which improves the stock DAC on the MiSTer and really improves the sound. A lot.This unit is powered with PicoPSU (included) and 12v power adapter (also included)! A Noctua case fan is installed to bring in fresh air.This also has an MT32-pi installed INSIDE the case! The MT32-pi uses a Pi Zero (included and installed) to emulate an MT32. This internal version does require custom-patched cores to use; I have included patched Atari ST, Amiga, PC, and X68000 cores on the SD card.Also included is an Amiga "tank style" wireless mouse. This was a Kickstarter a ways back and is a Bluetooth/WiFI mouse that looks like an Amiga mouse. This is the "beige" style and includes a dongle that when plugged into the MiSTer, works perfect!
Thanks!
