Because you are using English measurement locks, VLX is Japanese/metric.
Official is LY1153 (tubular key) for everything but coin box, that is first (dimple key).
OVS@taito.co.jp
E5000630A LOCK LY-1153 SINGLE(F750-MSDS) @JPY1,040
E5000631A KEY LY-1153(F750-MSDS) @JPY650
Sorry I don't have the First lock/key part number, I think @KinG_SoPa might have it.
When it comes to the coin box, that security ring adds some thickness as well.17.4mm depth.... that's a weird size.
17.4mm depth.... that's a weird size. But thanks for the links! Will compare against some measurements I've taken and against the locks I just bought.
On mine this (5/8th) causes the doors to rattle (tang had too much play).which is close but not quite
Actually IF you use the right locks, you get zero rattle... Thats the first sign its NOT correct.a lot of these locks have a bit of slack which may cause the aforementioned rattle.
I was referring to the cheap 5/8s locks (https://www.ebay.com/itm/173529108259) that I see used a lot. They seem to be +/- 10% in size...Actually IF you use the right locks, you get zero rattle... Thats the first sign its NOT correct.
This is correct E5000632A KIND LOCK (LARGE RING) F830(2KEY)E5000632A KIND LOCK (LARGE RING) F830(2KEY)
This was for egret 3, vewlix number may be E5000678A but should be the same.
http://www.firstlock.co.jp/products/kind-lock/f830.html
